 Hunting for a component - help sought.
Hunting for a component - help sought. Empty
PostSubject: Hunting for a component - help sought.   Hunting for a component - help sought. I_icon_minitimeMon Feb 24 2014, 14:48
I've got a project on the go, but I'm after a good, strong component for part of it that will hold a vital piece together.
I need eight "things" that look like this:
Hunting for a component - help sought. Stick1_zpsfed785b3
The btt0om stick doesn't have to be squared, rounded would work just as well. In total, maybe somewhere between 1" to 1.5".
For the vital part right now I need eight of these, but more would be very useful later in the build.
Any tips you might have of where I can find something solid that would work (and by solid, I mean this is needed to afford stability to a vital part, so something in pieces might not work as well).
Helps and tips always welcome.
Thanks.
PostSubject: Re: Hunting for a component - help sought.   Hunting for a component - help sought. I_icon_minitimeMon Feb 24 2014, 15:03
Looks kind of like a match to me... Would they work?
PostSubject: Re: Hunting for a component - help sought.   Hunting for a component - help sought. I_icon_minitimeMon Feb 24 2014, 15:12
Nay. Plastic would be best, though metal equally good and less combustible Very Happy. The flat end at the top is also fairly necessary.
Aeterna
Aeterna
PostSubject: Re: Hunting for a component - help sought.   Hunting for a component - help sought. I_icon_minitimeMon Feb 24 2014, 15:23
http://www.games-workshop.com/gws/catalog/productDetail.jsp?catId=cat470008a&prodId=prod1390090a
Decent price about a $1 per stand
"Hear our call children of the void, listen to the screams of your brothers and sisters, see the raining ash from your home. Do you have what it takes to stand back up, or will you fall like so many before you."
        -  Zorev Norterus, Archon of the Immortal Eclipse
                Kabal of the Immortal Eclipse | Coven of the Shadow Flesh | Cult of the Black Rage
BlckRven
BlckRven
PostSubject: Re: Hunting for a component - help sought.   Hunting for a component - help sought. I_icon_minitimeMon Feb 24 2014, 22:00
maybe some plasticard rods. I believe they make um fairly small. just cut, grind and glue. I found that the platiscard is really easy to glue and holds pretty good.
You might also want to check 3D printing. It becomes more and more affordable since you can bassically get do-it-yourself 3D printers. Maybe you have a company somewhere in the area that accepts jobs. Usually 3D polymers are comparible to ABS. (the stuff your vacuum cleaner is probably made off)
Hunting for a component - help sought. Signat10
Barking Agatha
Barking Agatha
PostSubject: Re: Hunting for a component - help sought.   Hunting for a component - help sought. I_icon_minitimeMon Feb 24 2014, 22:24
Could you use a length of sprue with the peg bit on the end?
House of the Bitter Laugh, uniting the Kabal of Scorn, the Cult of Disdain, and the Coven of Jaded Atrocities
PostSubject: Re: Hunting for a component - help sought.   Hunting for a component - help sought. I_icon_minitimeSun Mar 02 2014, 06:54
When i saw the picture i immediately thought - well that sprue.
