 Webway Portal Help
4 posters
Mt252368
Mt252368
Webway Portal Help Empty
PostSubject: Webway Portal Help   Webway Portal Help I_icon_minitimeSat Feb 16 2013, 20:56
Hey I'm just wondering how to create my own webway. I'm not sure what it should look like, the size, shape I should be using.
Any suggestions are welcome!
Ehawther
Ehawther
PostSubject: Re: Webway Portal Help   Webway Portal Help I_icon_minitimeSat Feb 16 2013, 21:22
Size is supposed to be a small blast marker. GW had released a "model" for it (I think) but it was easeily converted on your own. Half sphere with the same circumference as the small blast marker. Make it look all "potal-y" and bonus points if you can make it look like Commorragh is "in" the portal.
Mt252368
Mt252368
PostSubject: Re: Webway Portal Help   Webway Portal Help I_icon_minitimeTue Feb 19 2013, 03:53
Thanks!
xzandrate
xzandrate
PostSubject: Re: Webway Portal Help   Webway Portal Help I_icon_minitimeTue Feb 19 2013, 14:44
I had made some clear resin portals with a swirled pattern in them. While looking around I found that a Pringles lid was the perfect size to use as a mold.
Tony Spectacular
Tony Spectacular
PostSubject: Re: Webway Portal Help   Webway Portal Help I_icon_minitimeThu Feb 21 2013, 14:22
If you want it to be a 3D model I believe that standard wiffle balls fill the bill perfectly.
Edited for stupidity.
Webway Portal Help
