| talos pain engine, how to use? | |
+6mug7703 Bibitybopitybacon Azdrubael Seshiru Cavash shadowseercB 10 posters |
Author | Message |
shadowseercB Wych
Posts : 550 Join date : 2012-10-21
 | Subject: talos pain engine, how to use? Sun Oct 21 2012, 18:56 | |
| I have one pain engine. How do I get it into melee combat? Any other suggestions on use will be welcome.
Thanks | |
Cavash Lord of the Chat
Posts : 3237 Join date : 2012-04-15 Location : Stuck in an air vent spying on plotters
 | Subject: Re: talos pain engine, how to use? Sun Oct 21 2012, 19:17 | |
| Getting one into combat might be difficult the way that I use them. I tend to use at least two and have them at the centre or the front of my main force but in cover. The rest of my army is usually in Raiders which then rush forward and pose as a distraction while the Pain Engines march slowly forward ready to wreck face.
The other way to use them would be to use a WWP, but they can't assault after entering from it, so they could draw a lot of fire.
I hope this helps. | |
Seshiru Sybarite
Posts : 408 Join date : 2012-07-03
 | Subject: Re: talos pain engine, how to use? Mon Oct 22 2012, 15:20 | |
| The Splinter Cannon is nice because you don't need to get close. _________________ The worst sort of protection is confidence. The best defense is suspicion.
Azdrubael Incubi
Posts : 1857 Join date : 2011-11-16 Location : Russia
 | Subject: Re: talos pain engine, how to use? Mon Oct 22 2012, 16:22 | |
| You also want to run with MC... _________________ The Dance of Death begins - embraces, caresses, and kisses, The Harlequin loves you as you fall over in pieces!
Bibitybopitybacon Wych
Posts : 592 Join date : 2012-07-01
 | Subject: Re: talos pain engine, how to use? Tue Oct 23 2012, 05:35 | |
| Dropping a couple armed with heatlances and liquifiers out of a WWP into the other guys face could work although, depending on how close you can get, the Haywire blaster may be a better investment. Even though you can't assult after comming out of reserve you can still melt face with a twin linked liquifier or pop a transport with one and then melt the people inside with the other ones acid sprayer (a chronos could be fun against a foot slogging army of MEQ. A Strength 4 AP3 flamer and an AP 3 large blast can ruin any SM's day, not to mention the pain tokens you get.) | |
mug7703 Sybarite
Posts : 409 Join date : 2012-09-19 Location : Brighton
 | Subject: Re: talos pain engine, how to use? Tue Oct 23 2012, 12:11 | |
| How would people equip and use two Taloi in a fast army that is going to race up the field on turn 1? I'm thinking I'd use two and have them camp on objectives denying the enemy or slowly march up to their lines largely ignored due to everything else being in their face.
I can't decide between keeping them stock, or just equipping them with a LFG for 105pts or just a haywire blaster for 105pts.
It's a tough call. | |
Darklight Sybarite
Posts : 384 Join date : 2011-05-27 Location : Stavanger
 | Subject: Re: talos pain engine, how to use? Tue Oct 23 2012, 13:18 | |
| Not a fan of talos, but I would load it with Haywire blasters, as I am a huge fan of those. _________________ Plays Dark Eldar, Eldar and Harlequins. If you are from norway, check out www.drittunger.no
Mushkilla Arena Champion
Posts : 4017 Join date : 2012-07-16 Location : Toroid Arena
 | Subject: Re: talos pain engine, how to use? Tue Oct 23 2012, 13:57 | |
| I would go Twin-liquefier always, and then it's a toss up between haywire and splinter cannons. Heatlances should only really be used when coming out of a portal. | |
mug7703 Sybarite
 | Subject: Re: talos pain engine, how to use? Tue Oct 23 2012, 14:15 | |
| - Mushkilla wrote:
- I would go Twin-liquefier always, and then it's a toss up between haywire and splinter cannons. Heatlances should only really be used when coming out of a portal.
Yea I think the LFG is pretty amazing and the only twin-linked one in the codex and for only 5pts! I think the SCs are good enough and means it can do damage before getting near the enemy but I'd have to try out both. | |
Rancid blade Kabalite Warrior
Posts : 151 Join date : 2011-05-27
 | Subject: Re: talos pain engine, how to use? Tue Oct 23 2012, 21:13 | |
| I run two of these kittens. I give them haywire blasters, chain flails and a CCW. If you need them to sit back and shoot vehicles, then they're great. If you get them into the fight they'll make chop sui of most close combat units. T7 and 3+ save makes them pretty resilient. With the changes to FNP they're better than they were once they get a PT. Since they're slow they make a great counter attack unit.
Another advantage is that people don't see them often and so they don't really understand what they can do. Up to 8 attacks on the charge at str7, and AP2 is gruesome.
One draw back is once someone sees your talos take out three or four terminators in one turn they will make the talos a priority.
Keep them away from force weapons... | |
Seshiru Sybarite
 | Subject: Re: talos pain engine, how to use? Tue Oct 23 2012, 23:05 | |
| The recent FAQ on how Smash attacks work really benefits the Tallos with the Random Attacks (halving the base rounded up then adding in all other attacks)
If you roll say a 1, then you still get your bonus attack for charging, and potentially your bonus for extra weapon (if you took an extra cc weapon) but they are all at str 10.
If you roll a 3 then could lose 1 attack in exchange for being at 10 str, which may matter for instant death purposes etc.
Not a fan of the Haywire Blaster, it basically aims to strip away one hull point and most vehicles have 3, three turns of shooting with your Tallos on a vehicle is a waste IMO _________________ The worst sort of protection is confidence. The best defense is suspicion.
xzandrate Kabalite Warrior
Posts : 205 Join date : 2011-05-20 Location : Northern Ontario
 | Subject: Re: talos pain engine, how to use? Wed Oct 24 2012, 16:47 | |
| Talos wouldn't be your primary AT with the haywire, but it's great to have as the mop up guy to finish off that last hull point on a vehicle.
If your darklight weaponry is anything like mine you will need him to do that alot. | |
 | Subject: Re: talos pain engine, how to use?  | |
