 Venom Blade and Huskblade
4 posters
Bookkeeper
Bookkeeper
Venom Blade and Huskblade Empty
PostSubject: Venom Blade and Huskblade   Venom Blade and Huskblade I_icon_minitimeFri Sep 21 2012, 13:18
I saw several people describing their Archon's loadout as carrying both of these weapons. How does that work in play? It seems that, per the rules, you can't combine the effects, so do you choose each round (that is, this round I wound you on a 2+. next round, if you take a wound you die)?
tlronin
PostSubject: Re: Venom Blade and Huskblade   Venom Blade and Huskblade I_icon_minitimeFri Sep 21 2012, 13:40
You choose each fight-subphase which weapon you use.
Archon of the kabal of The Bleeding Hand.
Member of local Dutch community: http://www.sweetlakesentinels.nl
Kayto_Karite
PostSubject: Re: Venom Blade and Huskblade   Venom Blade and Huskblade I_icon_minitimeFri Sep 21 2012, 16:00
Is correct.
Now I will explain why this is a good option. See in 5th if you had any kind of Special Weapon (exluding TH, PF, CF, and LC) you could only get +1 Attack if you also had a pistol or CCW.
5th Edition Example:
Venom Blade + Huskblade = No +1 Attack
Venom Blade + Splinter Pistol (or CCW) = +1 Attack
In 6th edition they change that rule. As long as your weapon doesn't have the Specialist rule you can always get the +1 Attack if you have any kind of pistol or Melee Weapon.
6th Example:
Venom Blade + Huskblade = +1 Attack
Power Fist (Specialist) + Bolt Pistol = No +1 Attack
So this now gives the Archon options depending what he/she has to fight. You can now go against any kind of MC and still wound a 2+ or go against a T4 or less and use the Huskblade.
”We the unwilling, led by the ungrateful, are doing the impossible. We've done so much, for so long, with so little, that we are now qualified to do something with nothing." - Konstantin Josef Jireček
My Dark Eldar Blog: The Shardnet and Impaler - Dark Eldar Lists
http://www.theshardnetandimpaler.com/
Bookkeeper
Bookkeeper
PostSubject: Re: Venom Blade and Huskblade   Venom Blade and Huskblade I_icon_minitimeFri Sep 21 2012, 18:21
Thanks for the replies! I'm assembling my Archon now, so I'm in quandary about how to arm him.
PostSubject: Re: Venom Blade and Huskblade   Venom Blade and Huskblade I_icon_minitimeFri Sep 21 2012, 18:38
I don't think you can go wrong with:
Archon, SField, STrap, HBlade, VBlade - 140pts
Husktrap archons were a lot of fun to play in 5th and now the Huskblade got better (because everything else got worse), you can use the Venom blade as a backup weapon and challenges make soul trapping easier, not to mention archons are generally more survivable this edition thanks to Look Out Sir.
