 9th ed Mathammer Thread
AlCorps
9th ed Mathammer Thread Empty
PostSubject: 9th ed Mathammer Thread   9th ed Mathammer Thread I_icon_minitimeMon Mar 29 2021, 16:57
Greetings, puny mortals.
This thread is to show the value of different weapon/drug/relic/warlord options on various units.
The aim is to get an "in a vacuum" idea of the best unit for a task, compared unit to unit and per points cost.
I've started with scourges, as they have had a lot of weapon changes, and contain most of the special/heavy weapons also available to other units.
Each table contains a target, the weapons are ranked by points efficiency.
The shots, hits, wounds, and unsaved columns from the spreadsheet are left out to save space, only the final damage and damage-per-point are posted.
A note on damage calculations: I've capped the damage of a weapon by the number of wounds it can do to a model in that unit. This has the effect of lowering the points efficiency of some weapons, but gives a closer idea of how many models could be killed in practice.
EG a blaster can do a max of 2 damage to a primaris marine, so it's damage is averaged at 2 rather than 3.5.
Light and normal infantry.
TargetWeaponDamageDamage per point
10 Guardsman (t3, 1w, 5+)4 Shredders (6+ blast)7.4074074070.09259259259
4 Splinter Cannon2.50.025
4 Blasters2.2222222220.02222222222
4 Haywire Blasters1.6666666670.01666666667
4 HeatLance1.6666666670.01666666667
4 Dark Lance1.6666666670.01388888889
Primaris (t4, 2w, 3+)4 Blasters4.0740740740.04074074074
4 Shredders3.1111111110.03888888889
4 HeatLance3.3333333330.03333333333
4 Splinter Cannon30.03
4 Dark Lance3.3333333330.02777777778
4 Haywire Blasters1.8518518520.01851851852
Unsurprisingly, shredders are good against guardsmen.
The big takeaway here is that Blasters tend to be the best option, as they don't suffer the heavy penalty all the other weapons do.
The -1 to hit for heavy weapons (assuming you are moving you scourge...) is a big reduction in reliable damage.
Heavy infantry
Gravis (t5, 3w, 3+)4 Blasters4.4444444440.04444444444
4 HeatLance40.04
4 Dark Lance40.03333333333
4 Haywire Blasters2.2222222220.02222222222
Bladeguard4 Blasters2.7777777780.02777777778
4 Shredders2.0740740740.02592592593
4 HeatLance2.50.025
4 Dark Lance2.50.02083333333
4 Splinter Cannon20.02
4 Haywire Blasters1.3333333330.01333333333
Terminator (t4, 3w, 2+, 5++)4 Blasters3.7037037040.03703703704
4 Haywire Blasters1.7777777780.01777777778
Again, Blasters are the best, but Heat Lances are making a good showing due to their high damage. If they can hit, they do a lot of damage.
Super-heavy infantry
Terminator SS (t4, 1+, 4++)4 Blasters2.7777777780.02777777778
4 HeatLance2.50.025
4 Shredders1.0370370370.01296296296
4 Splinter Cannon10.01
Transhuman Gravis4 Blasters3.3333333330.03333333333
4 HeatLance30.03
4 Shredders2.3333333330.02916666667
4 Dark Lance30.025
Super Tough Nurgle Terminator (t5, 3w, 2+. 5++, -1d)4 Shredders2.0740740740.02592592593
4 Blasters2.5679012350.02567901235
4 HeatLance2.5185185190.02518518519
4 Dark Lance2.6666666670.02222222222
4 Haywire Blasters1.1851555560.01185155556
Blasters are still the best, Heat Lances are close behind.
Any sort of invulnerable save, transhuman, or -1 damage, and the efficiency of these weapons plummets.
Big targets
Outrider/Attackbike (t5, 4w,3+)4 Blasters5.3333333330.05333333333
4 HeatLance5.1111111110.05111111111
4 Dark Lance5.3333333330.04444444444
Rhino4 HeatLance7.3333333330.07333333333
4 Blasters6.2222222220.06222222222
4 Dark Lance6.6666666670.05555555556
4 Haywire Blasters4.6666666670.04666666667
4 Shredders1.5555555560.01944444444
Knight (t8, w24, 3+, 5++)4 Haywire Blasters40.04
4 HeatLance3.6666666670.03666666667
4 Blasters3.1111111110.03111111111
Some things change here.
Blasters are still good, but once the target gets above the 4 wound mark, the Heat Lance really starts to punch. The much higher average damage kicks in, if you roll hot then a rhino could be killed in 1 volley, even with the heavy penalty.
The haywire blaster finally sees some use against knight targets, but it's only just ahead of the Heat Lance.
Remaining Stationary
For funzies, I did two targets with the scourge Remaining Stationary, to show the effect of the heavy penalty.
Gravis (t5, 3w, 3+)4 HeatLance (stationary)5.3333333330.05333333333
4 Dark Lance (stationary)5.3333333330.04444444444
4 Splinter Cannon (stationary)40.04
4 HeatLance40.04
4 Haywire Blasters (stationary)2.9629629630.02962962963
Knight (t8, w24, 3+, 5++)4 Haywire Blasters (stationary)5.3333333330.05333333333
4 HeatLance (stationary)4.8888888890.04888888889
4 Dark Lance (stationary)4.4444444440.03703703704
4 Splinter Cannon (stationary)1.3333333330.01333333333
Next up, I'll post a list of the popular anti-tank options against standard tank targets.
Soulless Samurai
Soulless Samurai
PostSubject: Re: 9th ed Mathammer Thread   9th ed Mathammer Thread I_icon_minitimeMon Mar 29 2021, 17:12
It's a nice idea but I fear your math might be off in places.
At a glance, on the top table you've got Dark Lances and Heat Lances both doing less damage then Blasters - which is impossible as they have the exact same statlines, only with better damage characteristics.
I've got Heat Lances doing 4.44r wounds to a Primaris Marine, not 3.33r.
Against GEQ, they should all be doing the same damage (as the only difference between them for the purposes of this table is the damage characteristic).
@TeenageAngst wrote:
Never trust the French.
AlCorps
PostSubject: Re: 9th ed Mathammer Thread   9th ed Mathammer Thread I_icon_minitimeMon Mar 29 2021, 17:28
I should probably explain the tables a bit better. Shots,Hits,Wounds,Unsaved columns are left out. Just the final damage step, and damage-per-point are posted.
So a blaster does more damage to guardsmen than a dark lance, as it will have hit more times.
red_head likes this post
Soulless Samurai
Soulless Samurai
PostSubject: Re: 9th ed Mathammer Thread   9th ed Mathammer Thread I_icon_minitimeMon Mar 29 2021, 17:41
Oh so you're assuming that Heavy weapons have always moved before firing then?
Okay, I think I get you now.
My mistake then. Apologies.
Dalamar
PostSubject: Re: 9th ed Mathammer Thread   9th ed Mathammer Thread I_icon_minitimeMon Mar 29 2021, 22:48
think the Haywire Blaster is off. it is a d3 Blast weapon, so if it target the Guardsmen for instance it is 12 shots, 6 hit, 3 wound, 3 damage if we keep the damage cap at 1, while moving. 4 damage if stationary. have to remember those blast rules.
Dark Elf Dave
Dark Elf Dave
PostSubject: Re: 9th ed Mathammer Thread   9th ed Mathammer Thread I_icon_minitimeTue Mar 30 2021, 00:32
This is cool. Would have rather seen the results without the -1 for moving penalty as most Dark Lances will be on Raiders/Ravagers. Also Heat Lances will most likely be seen on Reavers so again no penalty.
