 How does the Haywire rule interact with the psychic power Doom?
jjw771
jjw771
How does the Haywire rule interact with the psychic power Doom? Empty
PostSubject: How does the Haywire rule interact with the psychic power Doom?   How does the Haywire rule interact with the psychic power Doom? I_icon_minitimeFri Jul 20 2018, 20:23
Doom is worded as such: Targets a single enemy unit within 24". Re-roll all failed to-wound rolls against the unit until the next psychic phase.
While the Haywire weapons cause a mortal wound on a 4+ regardless of if a wound was caused or not
So my question is if the Haywire blaster is shooting at a vehicle that requires a 5+ to wound and the vehicle has the Doom psychic power cast on it, am I re-rolling 1's, 2's, and 3's or am I re-rolling the 4's as well?
PostSubject: Re: How does the Haywire rule interact with the psychic power Doom?   How does the Haywire rule interact with the psychic power Doom? I_icon_minitimeFri Jul 20 2018, 20:42
I think 4 as well since you actually fail to wound.
Sent from Topic'it App
jjw771
jjw771
PostSubject: Re: How does the Haywire rule interact with the psychic power Doom?   How does the Haywire rule interact with the psychic power Doom? I_icon_minitimeFri Jul 20 2018, 21:28
@CptMetal I think it really comes down to; is causing a mortal wound count as a successful wound roll?
Shride
Shride
PostSubject: Re: How does the Haywire rule interact with the psychic power Doom?   How does the Haywire rule interact with the psychic power Doom? I_icon_minitimeFri Jul 20 2018, 21:53
My gut said re-roll 4's, but after re-reading the HWB rules, I've swung to the other side of the fence and say no, you don't re-roll them.
Haywire Blaster Abilities wrote:
If the target is a VEHICLE and you roll a wound roll of 4+ for this weapon, the target suffers a mortal wound in addition to any other damage.
Even if there is no other damage, that mortal wound still successfully got through.  So, it successfully wounded.  No Doom re-roll required.
But I could definitely be wrong on this.  Just tossing in my $0.02.
PostSubject: Re: How does the Haywire rule interact with the psychic power Doom?   How does the Haywire rule interact with the psychic power Doom? I_icon_minitimeFri Jul 20 2018, 22:33
Reading that I'd stick with your initial gut feeling. The Doom power refers to the Wound roll, not whether the target takes a wound. Obviously that's normally the same thing but in the case of the haywire rules you could fail a wound roll but still inflict a mortal wound.
I'd definitely be re-rolling the 4's in the scenario given as they failed the wound roll, regardless of any other effect that may have occurred.
How does the Haywire rule interact with the psychic power Doom? YhBv3Wk
dumpeal
dumpeal
PostSubject: Re: How does the Haywire rule interact with the psychic power Doom?   How does the Haywire rule interact with the psychic power Doom? I_icon_minitimeFri Jul 20 2018, 22:41
You reroll the 4, for the purpose of determining if the normal wound lands. Then, you roll your mortal wounds, without rerolls.
PostSubject: Re: How does the Haywire rule interact with the psychic power Doom?   How does the Haywire rule interact with the psychic power Doom? I_icon_minitimeFri Jul 20 2018, 23:04
Eh? What do you mean? There is no separate roll for mortal wounds. They're an additional effect of the wound roll.
Hypothetical example - 10 hits from a haywire weapon (S4) against a T5 target, so 5+ needed to wound. Wound rolls of 1, 1, 2, 3, 3, 4, 4, 5, 6, 6. With the Doom power you would re-roll failed wound rolls, ie anything less than 5+. So you re-roll the 1, 1, 2, 3, 3, 4, and 4, this time getting 1, 2, 3, 3, 4, 5, 6 giving us a final array of 1, 2, 3, 3, 4, 5, 5, 6, 6, 6. This gives 5 normal wounds (5, 5, 6, 6, 6) and 3 mortal wounds (6, 6, 6). The rest do nothing.
Gorgon
Gorgon
PostSubject: Re: How does the Haywire rule interact with the psychic power Doom?   How does the Haywire rule interact with the psychic power Doom? I_icon_minitimeSat Jul 21 2018, 02:58
Straight from my codex:
Doom has a warp charge value of 7. If manifested, choose an
enemy unit within 24" of the psyker. You can re-roll failed wound
rolls against that unit until your next Psychic phase.
The word "can" in there tells me that you can leave 4s if you want.
yellabelly
yellabelly
PostSubject: Re: How does the Haywire rule interact with the psychic power Doom?   How does the Haywire rule interact with the psychic power Doom? I_icon_minitimeSat Jul 21 2018, 06:36
@Count Adhemar haywire inflict single mortal wounds on a 4+, and D3 mortal wounds on a 6+. So your example would inflict a tasty 3D3+2 mortal wounds on a vehicle. Definitely agree on rerolling 4s, it's a failed wound roll vs T5+.
Do you fight for the Dark Gods? The Drukhari gave birth to one of them. By partying.
PostSubject: Re: How does the Haywire rule interact with the psychic power Doom?   How does the Haywire rule interact with the psychic power Doom? I_icon_minitimeSat Jul 21 2018, 19:26
My bad Embarassed I think I was thinking of sniper rifles lol
