 fire dragons as true born with blaster?
View previous topic View next topic Go down
rwatts
PostSubject: fire dragons as true born with blaster?   Sat Nov 26 2011, 06:21
hey first post, just wanted to see what people thought about the idea given how hard I have found it to get blasters on the net.
cheers guys
Marquis Vaulkhere
PostSubject: Re: fire dragons as true born with blaster?   Sat Nov 26 2011, 06:26
I think thats a great idea Rwatts. With the new finecast firedragons it would be a sinch to remove the heads and do some tweeking to the armour. Good thinking there.
"The only constant in the universe is pain."
~Coven of the Splinterd tongue: Project Log
PostSubject: Re: fire dragons as true born with blaster?   Sat Nov 26 2011, 07:42
Yeah, that looks pretty bankable as a conversion - aesthetically the big goal would be getting some spikes and sharper edges to all those curving Eldar bits.
PostSubject: Re: fire dragons as true born with blaster?   Sat Nov 26 2011, 09:16
"Off with their heads!"
Agreed, this would make a very good conversion. Expensive, but good.
BTW - I'm moving this to the Painting and Modelling Discussion.
rwatts
PostSubject: Re: fire dragons as true born with blaster?   Sat Nov 26 2011, 11:37
Cheers guys. Sorry it was in the wrong section, was just wanting to run the idea by people to double check if people thought this would be an acceptable representaion.
Cheers
PostSubject: Re: fire dragons as true born with blaster?   Sat Nov 26 2011, 12:50
(Pardon for crappy picture + awful paintjob, not mine minis)
Dunno. With proper paintjob they should look ok...
Helmets with "tusks", metal plume - that scream DE Aristocrats (no joke intended) for me. I would only add spikes/blades on shoulder pads or barbed mohawk.
PostSubject: Re: fire dragons as true born with blaster?   Sat Nov 26 2011, 15:10
Should work out pretty well with a head swap, but whatever you do :DON'T PAINT THEM LIKE THIS!!!! affraid It would really defile everything that is DE. Very Happy I'm down with purple, but these made me throw up in my mouth a bit. tongue
Shadows Revenge
Hierarch of Tactica
PostSubject: Re: fire dragons as true born with blaster?   Sat Nov 26 2011, 16:28
I wouldnt even switch heads, as they look like the older DE style with the pony tailesque things. If you have the newer models then sure, head-swap to your hearts content. What I would do is remove those soulstones... its just so blah... Razz
Status:
Current List:
First 2k GSC List
PostSubject: Re: fire dragons as true born with blaster?   Sat Nov 26 2011, 16:50
The old pony tail things looked nothing like the FD's plume - the plume has always been Eldar looking wen neat, and DE looking when longer and more gnarled and wind-tossed looking.
rwatts
PostSubject: Re: fire dragons as true born with blaster?   Sun Nov 27 2011, 06:04
Luckily I have so many old warriors I don't intend on buying more anytime soon, my initial thoughts were to just remove the soul stones and minor conversion work, eg Adding spikes to back of the head. I'm glad I have had positive feed back, I'm not just wanting to be a cheap scate as its an expensive enough purchase, it was just wanting cool models that I could actually get hold of lol. But I'm glad the gaming comunity sees this as a valid idea and I hope anyone else that was struggling to get hold of the illusive blaster will use the idea!
Cheers
rwatts
PostSubject: Re: fire dragons as true born with blaster?   Sun Nov 27 2011, 06:14
Ps, yeh I don't intend on using this kabals colour or markings. Not really my cup of tean but each to there own, Someone must have appreciated it Smile
Cheers
PostSubject: Re: fire dragons as true born with blaster?   Sun Nov 27 2011, 06:59
Cheers
And that someone was clearly color-blind or on LSD cyclops
rwatts
PostSubject: Re: fire dragons as true born with blaster?   Sun Nov 27 2011, 08:44
Lol probably the same guy that came up with betty boop and magic roundabout! Have you seen that stuff..... Wow
PostSubject: Re: fire dragons as true born with blaster?   Sun Nov 27 2011, 15:28
I've had the same idea of using Fire Dragons as Blasterborn for a long time. Personally, I'd just give them a paint job that goes with the rest of my Blasterborn, without going for adding all the spikes and blades. In any case, Fire Dragons as Blasterborn is probably a good alternative if you're not into converting the blasters from Shredders or not feeling like ebaying the bits.
The Wailing Doom corsairs project log
Craftworld Nemirath project log
Siticus Miniatures Painting - my Facebook page with all my miniatures painting updates
PostSubject: Re: fire dragons as true born with blaster?   Mon Nov 28 2011, 15:44
I think that you could make some Commorragh aligned Corsairs that are taking part in the realspace raids just for the lulz. I'm doing something similar using the FW Corsairs to make my Trueborn (as all Craftworld Eldar are essential 'trueborn' to some degree).
Look at giving them all unhelmeted heads from across the GW Eldar and Elven ranges; fur and tribal tattoos always reinforce the barbaric look.
http://www.thedarkcity.net
View previous topic View next topic Back to top
