 Razorwing jet and fire & fade
Hen Tai, the tentacle guy
Razorwing jet and fire & fade Empty
PostSubject: Razorwing jet and fire & fade   Razorwing jet and fire & fade I_icon_minitimeSat Apr 07 2018, 14:04
Is it possible to use fire & fade on razorwings or the voidraven, to do a shorter 90° turn?
A Sybarite is never sybawrong...
I have a project log. http://www.thedarkcity.net/t14639-kabal-coven-wych-cult-and-harlequinsyyy
AzraeI
AzraeI
PostSubject: Re: Razorwing jet and fire & fade   Razorwing jet and fire & fade I_icon_minitimeSat Apr 07 2018, 14:26
as fun as it would be i dont think its possible, the BRB states if a model cannot make its minimum move it is destroyed
PostSubject: Re: Razorwing jet and fire & fade   Razorwing jet and fire & fade I_icon_minitimeSat Apr 07 2018, 14:55
Hmm. Its questionable as to whether the minimum move was covered in the movement phase, and if it would apply here. WOrth asking I think.
Burnage
Burnage
PostSubject: Re: Razorwing jet and fire & fade   Razorwing jet and fire & fade I_icon_minitimeSat Apr 07 2018, 15:19
It's not making a standard move, though, it's just moving a flat 7 inches. The 20 inch minimum move doesn't sound like it relates to it at all.
AzraeI
AzraeI
PostSubject: Re: Razorwing jet and fire & fade   Razorwing jet and fire & fade I_icon_minitimeSat Apr 07 2018, 15:38
yes its not a standard move, but the stratagem says the unit moves as if it were the movement phase, where the minimum movement distance takes precedence, until the faq, i dont think you can use this strtgm on a razorwing
Dalakh
Dalakh
PostSubject: Re: Razorwing jet and fire & fade   Razorwing jet and fire & fade I_icon_minitimeSat Apr 07 2018, 15:41
I don't see why there should be a FAQ on that anyway.
AzraeI
AzraeI
PostSubject: Re: Razorwing jet and fire & fade   Razorwing jet and fire & fade I_icon_minitimeSat Apr 07 2018, 15:43
because you could argue that minimum move rules apply in the movement phase, fire and fide happens in the shooting phase, and fire and fade is not a standard move
Burnage
Burnage
PostSubject: Re: Razorwing jet and fire & fade   Razorwing jet and fire & fade I_icon_minitimeSat Apr 07 2018, 15:53
Turns out that this has already been FAQed for the Craftworlds Codex, if you use Fire and Fade on a supersonic flier it does crash.
So that's cool.
AzraeI
AzraeI
PostSubject: Re: Razorwing jet and fire & fade   Razorwing jet and fire & fade I_icon_minitimeSat Apr 07 2018, 15:54
So that's cool.
ah allright, i just wanted to check that, thx
Dalakh
Dalakh
PostSubject: Re: Razorwing jet and fire & fade   Razorwing jet and fire & fade I_icon_minitimeSat Apr 07 2018, 16:26
So that's cool.
As per the rule as written initially.
PostSubject: Re: Razorwing jet and fire & fade   Razorwing jet and fire & fade I_icon_minitimeSat Apr 07 2018, 17:25
Good to know.
PostSubject: Re: Razorwing jet and fire & fade   Razorwing jet and fire & fade I_icon_minitimeSat Apr 07 2018, 17:51
If crash and burn was a 100% chance to do MW and you only had 1 wound left, heck i would do it lol.
