| Start Collecting! Dark Eldar incoming! | |
Author | Message |
Kantalla Wych
Posts : 725 Join date : 2015-12-21
 | Subject: Re: Start Collecting! Dark Eldar incoming! Sun Jun 26 2016, 05:54 | |
| - @nerdelemental wrote:
- Does the P.E. stack with twin link (from Splinter Rack)? Or do you have to choose one or the other?
Can't reroll a dice twice, so one or the other. |
Count Adhemar Dark Lord of Granbretan
Posts : 7075 Join date : 2012-04-26 Location : London
 | Subject: Re: Start Collecting! Dark Eldar incoming! Sun Jun 26 2016, 09:01 | |
You could however reroll all misses from the splinter racks and still re-roll 1's to wound from PE. _________________ You have been weighed, you have been measured, and you have been found wanting. In what world could you possibly beat me? |
The goat Hellion
Posts : 57 Join date : 2016-06-01
 | Subject: Re: Start Collecting! Dark Eldar incoming! Sun Jun 26 2016, 09:47 | |
amishprn86 Trueborn
Posts : 2903 Join date : 2014-10-04 Location : Ohio
 | Subject: Re: Start Collecting! Dark Eldar incoming! Sun Jun 26 2016, 12:41 | |
They both rerolls Ones to Hit (so those dont stack), but PE rerolls 1's to wound also. |
Marrath Wych
Posts : 670 Join date : 2014-01-01 Location : A very spiky Webway-Hulk
 | Subject: Re: Start Collecting! Dark Eldar incoming! Sun Jun 26 2016, 13:26 | |
Not quite, sorry. Twin linked re-rolls al failed to hit rolls, not just ones. So you can re-roll all failed to hit, and all ones to wound, if you have splinter racks and marked for death. Edit: What Count Adhemar said. |
amishprn86 Trueborn
 | Subject: Re: Start Collecting! Dark Eldar incoming! Sun Jun 26 2016, 15:40 | |
Oops yeah You are 100% right I wasnt thinking SR was TL, for some reason I was thinking they reroll 1's. Edit for spelling. |
fisheyes Wych
Posts : 843 Join date : 2016-02-18
 | Subject: Re: Start Collecting! Dark Eldar incoming! Mon Jun 27 2016, 09:18 | |
| Assuming we can get a Court in this formation, what would be the optimal load out? Lhameans wounding on 2s, resolving 1s? A whack of sslyth to protect the archon (who appears to need to be on foot to activate PE)? Medusae who will be *basically* wounding on 3s?
Doing a quick list it looks like about 500 puts for all the transports, blaster borne and the court |
amorrowlyday Hekatrix
Posts : 1291 Join date : 2015-03-15 Location : Massachusetts
 | Subject: Re: Start Collecting! Dark Eldar incoming! Mon Jun 27 2016, 16:09 | |
| At 500 points I can't find a way to afford the court.
Above that points total it would depend upon what I want to do with it. If I am trying to get some utility out of my archon by deepstriking or whatever it would be sslyths, otherwise a venom full of medusae if I can afford them, otherwise venom full of lhameans is probably my go-to.
Rokuro Wych
Posts : 619 Join date : 2014-11-25
 | Subject: Re: Start Collecting! Dark Eldar incoming! Fri Jul 01 2016, 17:46 | |
| To be sure, I talked to GW store employees this week. They meant that; yes, it would be possible to add a Venom for the Archon and another Raider/Venom for the Kabalite Warriors as dedicated transports - not a Court though, because it is a seperate unit, not an upgrade for the Archon, and the Retainers special rule only means it does not take up a FOC slot if an Archon is part of the same detachment, not that every detachment that includes an Archon may also include a Court.
P.S. I am still most sorry about my earlier misinterpretation. |
BetrayTheWorld Trueborn
Posts : 2665 Join date : 2013-04-04
 | Subject: Re: Start Collecting! Dark Eldar incoming! Fri Jul 01 2016, 21:54 | |
| - @Rokuro wrote:
- To be sure, I talked to GW store employees this week.
GW store employees are fairly notorious for being incorrect with rules interpretations. Just an FYI.  _________________  |
Rokuro Wych
 | Subject: Re: Start Collecting! Dark Eldar incoming! Sat Jul 02 2016, 07:19 | |
Since my own interpretations are now invalid by defaulf, I had to ask someone who is supposed to know the rules. At least I have confirmation now that my fault also extends to whatever outside sources I try to bring into arguments. |
Marrath Wych
 | Subject: Re: Start Collecting! Dark Eldar incoming! Sat Jul 02 2016, 10:24 | |
| If not even they can see through the mess that is their rulework consistently (my gw for example says everything goes, court, trueborn, los) how can it be expected of customers like you and me? Chill man! |
 | Subject: Re: Start Collecting! Dark Eldar incoming! Sat Jul 02 2016, 14:17 | |
Yeah, relax, man. I think GW store employees SHOULD know the rules well. They just often don't, and routinely disagree, just like players. So basically they're not an authority on rules is all I was saying. It had everything to do with your argument, and nothing to do with you. It's good to know, so that you know not to bother using some GW store guy as your supporting argument in the future. Now that you know, you'll be better prepared for your next debate.  _________________  |
Rokuro Wych
 | Subject: Re: Start Collecting! Dark Eldar incoming! Sat Jul 02 2016, 19:36 | |
- It's good to know, so that you know not to bother using some GW store guy as your supporting argument in the future. Now that you know, you'll be better prepared for your next debate.
I'm prepared for you to be there and dismiss everything I say. Hence there won't be a next debate. Congrats, you win by default. |
 | Subject: Re: Start Collecting! Dark Eldar incoming! Sat Jul 02 2016, 19:46 | |
You're debating with me right now about whether there will be another debate. And you lost again, haha. So at least you were right about that last part! _________________  |
 | Subject: Re: Start Collecting! Dark Eldar incoming! Sat Jul 02 2016, 20:43 | |
| All you've really demonstrated is that you've found a Gw employee who doesn't understand that formations are detachments and needs to reread the brb. |
stevethedestroyeofworlds Kabalite Warrior
Posts : 170 Join date : 2016-05-22
 | Subject: Re: Start Collecting! Dark Eldar incoming! Sat Jul 02 2016, 20:52 | |
| I have a Start Collecting in the mail. Really looking forward to the formation, even if there are difficulties getting the PE off every turn _________________ "Enemies are everywhere. Wisdom comes from knowing which ones to eliminate first"-Asdrubael Vect
 | Subject: Re: Start Collecting! Dark Eldar incoming! Sat Jul 02 2016, 21:13 | |
| I honestly don't even care about the PE. I feel like the most useful application of this unit is as an allied detachment without obsec or troops and an extra FA.
Marrath Wych
 | Subject: Re: Start Collecting! Dark Eldar incoming! Sat Jul 02 2016, 23:13 | |
| Do the Warriors of this formation and their transport even have objective secured? As they are not part of a combined arms detachment? |
 | Subject: Re: Start Collecting! Dark Eldar incoming! Sat Jul 02 2016, 23:15 | |
| Sorry that's a typo I will fix when I get to an actual computer. They DO NOT have obsec |
Imateria Sybarite
Posts : 482 Join date : 2016-02-06 Location : Birmingham
 | Subject: Re: Start Collecting! Dark Eldar incoming! Fri Jul 08 2016, 00:08 | |
| So I made use of this formation today against Grey Knights. Ran 6 Reavers with 2 CC, 10 Trueborn (4 Blasters, 2 Splinter Cannons, 4 rifles) in the Raider (Nightshields, Splinter Racks), Archon (Blaster and Shadowfield), Court of the Archon (4 Sslyth, Lhamaen) and a Venom. Comes out at 701pts, so not a small detachment. (My opponent seemed surprised that I'd ask him if taking the Court was OK, as far as he was concerned the Retainer rule made it pretty obvious you coul take a Court in a formation as long as there's an Archon.)
PE made a difference, turn 1 my Trueborn destroyed the first Dreadknight thanks to the extra hits and wounds the re-rolls gave them and later on my Reavers ran over the second thanks to PE. Definitely going to be running this formation again. |
colinsherlow Wych
Posts : 924 Join date : 2011-11-23 Location : Vancouver BC
 | Subject: Re: Start Collecting! Dark Eldar incoming! Tue Jul 12 2016, 15:17 | |
| What does this formation do?
The thread is fairly large and I don't have lots of free time to scan _________________ There are two things that I love. Kicking ass and chewing bubble gum... And I'm allllll out of bubble gum!
stilgar27 Sybarite
Posts : 468 Join date : 2012-12-04
 | Subject: Re: Start Collecting! Dark Eldar incoming! Tue Jul 12 2016, 17:14 | |
| - @colinsherlow wrote:
- What does this formation do?
Basically - it's an archon, a unit of kabalites, a raider, and a unit of reavers. The bonus is that at the beginning of each turn... if the archon is on the table he gets to "point" at one enemy unit in his line of sight, and everything in the formation gets preferred enemy against it (re-rolling 1s to hit and wound). It's underwhelming at first glance, especially if the archon is deep striking or depending on your interpenetration of whether he can actually "point" from within a transport, but it gets better when you realize you can buy add-ons like a seperate transport for the archon and the kabalites that fall in to the same formation/rule set (the raider isn't taken as a dedicated transport), and that the kabalites themselves can be upgraded to trueborn. Some argue that the rules for the court of the archon even allow for one to be included. Overall it's better than most of the "get started" bonuses, excluding some of the recent ones (like scions). I've long been an advocate of preferred enemy as a quick, fluffy fix to our mediocre book though so I was a little excited. Not excited enough to go to the storage unit and dig my dark eldar army out to try it... but almost. |
