 Eldar Power Maul
Rokuro
Rokuro
Eldar Power Maul Empty
PostSubject: Eldar Power Maul   Eldar Power Maul I_icon_minitimeFri Feb 05 2016, 20:18
As you know, the Craftworlders (unlike the Dark Kin) have access to not only Power Swords, but also to Lances (where they actually make sense), Axes and Mauls.
The model range gives us enough examples for the first three, but surprisingly not a single one for the Power Maul. Nada! Not even for their Fantasy or LotR counterparts!
Given, blunt force is not something associated with elves in any setting I know. But still, the option is there, and I want to make use of it.
So, any suggestions on how to build a lore-friendly Eldar Power Maul?
eohall
eohall
PostSubject: Re: Eldar Power Maul   Eldar Power Maul I_icon_minitimeFri Feb 05 2016, 23:48
plasma grenade on a stick? For DE I would use a Dark Elves scepter (black dragon kit)
stilgar27
stilgar27
PostSubject: Re: Eldar Power Maul   Eldar Power Maul I_icon_minitimeSat Feb 06 2016, 00:50
The Wraithblades' Ghost axe might be a good jumping off point, although that specific weapon is too big for average eldar hands.  Cut it down to the right size, remove the axe blade, and space 1-3 more spikes (or flanges) around the head and it might just work.
Eldar Power Maul Eldar_wraithguard_ghostaxe_large
Alternatively, there is always this guy in the wrack kit.
Eldar Power Maul Dark_eldar_wracks_right_arm_4_large
Rokuro
Rokuro
PostSubject: Re: Eldar Power Maul   Eldar Power Maul I_icon_minitimeSat Feb 06 2016, 02:01
There are also Dark "Aelf" maces in the Cold One Knights and Chariot kits. Or I could replace the head of an Impaler with that of a chain snare. But since Dark Eldar can't have Power Mauls, I'm looking specifically for a Craftworld- or High-"Aelf"-looking one.
A plasma grenade would be too small, sadly.
PostSubject: Re: Eldar Power Maul   Eldar Power Maul I_icon_minitimeSat Feb 06 2016, 12:51
I like the idea of it being closer to some sort of scepter than an actual maul. Alternatively, the 'Elven Mace' in Skyrim could provide some inspiration. It's more like an axe with four edges than a maul, but making that weapon could be fiddly if a substitute weapon can't be found.
Eldar Power Maul YiVCUio
Silverglade
Silverglade
PostSubject: Re: Eldar Power Maul   Eldar Power Maul I_icon_minitimeSat Feb 06 2016, 15:33
I think the piece from the wrack shown above is the best option.
The Shredder
The Shredder
PostSubject: Re: Eldar Power Maul   Eldar Power Maul I_icon_minitimeSun Feb 07 2016, 11:46
Yeah, I'd go with this too. Maybe have a lightning effect, implying that the weapon is less about brute force and more about delivering an electrical charge.
Rokuro
Rokuro
PostSubject: Re: Eldar Power Maul   Eldar Power Maul I_icon_minitimeSun Feb 07 2016, 14:47
Maybe I could do something with the head of this scepter.
Eldar Power Maul 87-21h10
It's not a very impressive looking weapon though. Neutral
Rokuro
Rokuro
PostSubject: Re: Eldar Power Maul   Eldar Power Maul I_icon_minitimeFri Feb 12 2016, 18:56
After grabbing the last Forsaken Ones box from my store (I still have a Chaos army after all - and why GW would even discontinue this unit is beyond me), I noticed it included a mace; suitably big, but strangely elegant and not even all that Chaos-y looking. So I decided to try and combine its head with the Wrack power maul as a shaft:
Eldar Power Maul 00112
It's a huge weapon for sure. But on the other hand, it is going to make an Eldar hit with Strength 5.
There's probably some form of anti-grav technology involved...
The Shredder
The Shredder
PostSubject: Re: Eldar Power Maul   Eldar Power Maul I_icon_minitimeFri Feb 12 2016, 19:05
I know you'll hate me for this, but you really wouldn't want anti-gravity on a maul.
Rokuro
Rokuro
PostSubject: Re: Eldar Power Maul   Eldar Power Maul I_icon_minitimeFri Feb 12 2016, 19:49
Don't worry, I don't.
What I meant is that the weapon becomes lighter to wield, but the effect could also be reversed when it hits.
The Shredder
The Shredder
PostSubject: Re: Eldar Power Maul   Eldar Power Maul I_icon_minitimeFri Feb 12 2016, 19:58
I've been trying to work out whether that would work, and I think my brain just melted. silent
Creeping Darkness
Creeping Darkness
PostSubject: Re: Eldar Power Maul   Eldar Power Maul I_icon_minitimeMon Feb 15 2016, 05:46
Anti-gravity would (presumably) negate the weight of the maul, but not the mass. So when swung, the maul would still retain all of the inertia of a body with that mass at that velocity, and be able to do significant damage to the unfortunate maulee. I think.
Granted, you would miss the acceleration due to gravity on the downswing, so you would have to do a bit more work to make sure it is up to speed. But since it wouldn't take as much effort to carry it around with you on the battlefield (and you could leave it hovering in the air while using your gun!) the average weedy space elf would probably come out ahead.
Or, it could be magic. I mean, it's your head-canon after all. Cool
FWIW I think it should look pretty cool. If it was held across the body into a gun-cradling arm it would bring a great "I'm going to beat your head to a pulp" vibe.
http://thecreepingdarkness.blogspot.com
The Shredder
The Shredder
PostSubject: Re: Eldar Power Maul   Eldar Power Maul I_icon_minitimeMon Feb 15 2016, 08:55
That's the thing though - most of the impact is from the weight, not the mass. The entire point of weapons like maces and mauls is that they're a weight on the end of a stick. Razz
stilgar27
stilgar27
PostSubject: Re: Eldar Power Maul   Eldar Power Maul I_icon_minitimeMon Feb 15 2016, 15:36
You'd basically want one of star trek's mythical "inertial dampeners" to control when and where inertia would apply to the weapon.  Not having to overcome initial inertia would mean you could swing it easily, like it was already moving.  If inertia was restored mid swing, it'd hit at full strength.  These dampeners would probably have to be pretty common in the universe anyway or crews would be plastered all over the inside of their battleships the first time it took a significant impact - the trick would be finding one that would fit in a weapon.
To be honest though the fluff guys never cared much about physics:
Rokuro
Rokuro
PostSubject: Re: Eldar Power Maul   Eldar Power Maul I_icon_minitimeFri Feb 19 2016, 19:11
I'm pretty sure the Eldar could have built something like that long before humans started building spaceships.
The Shredder
The Shredder
PostSubject: Re: Eldar Power Maul   Eldar Power Maul I_icon_minitimeFri Feb 19 2016, 19:18
Meanwhile, the humans shake their heads and just build some guns. Wink
The Red King
The Red King
PostSubject: Re: Eldar Power Maul   Eldar Power Maul I_icon_minitimeThu Feb 25 2016, 18:21
Try to find dark elf cold one riders mace bit. It looks great on my shadowseer conversion that I made last night
For Khaela Mensha Khaine!
Rokuro
Rokuro
PostSubject: Re: Eldar Power Maul   Eldar Power Maul I_icon_minitimeFri Feb 26 2016, 23:43
I have one. But I think it would suit a Dark Eldar, rather than a Craftworld Autarch.
The Red King
The Red King
PostSubject: Re: Eldar Power Maul   Eldar Power Maul I_icon_minitimeSat Feb 27 2016, 13:03
I converted a shadowseer miststave with it. Maybe trim the flanges a bit?
Eldar Power Maul
