 Help with making my 1850 into a 1250
doriii
PostSubject: Help with making my 1850 into a 1250   Thu Jan 07 2016, 20:37
Ok so here's the deal, I've got this 1850 list and i wanna know how to go about when sizing it down.
succubus
glaive,  HG,  leech pistol
105
3 grots in dissy raider
160pt
6x5 warriors. 1blaster, 1 sybarite/HG
dual cannon venoms
810pt
2xdual DL razorwings
280pt
5 scourge 4HWB
120pt
3xtriple DL ravagers
375pt
hydranixx
PostSubject: Re: Help with making my 1850 into a 1250   Thu Jan 07 2016, 20:53
It's a tough call.
Perhaps cutting back one ravager, one razorwing, two venom squads, the leech pistol and a syrabite here and there would get you close to your goal.
EDIT - if you cut exactly these 4 units, the pistol and every syrabite, you'd be at your goal.
If there's less emphasis on vehicles in your area, you could consider having dissies on the remaining razorwing and possibly on one of the ravagers, saving you a little extra.
I think at 1250 points, relying on scourges, the kabalite blasters and a single ravager supplemented by grots is enough. This isn't the case if your enemy spams tonnes of tanks though.
"Of course you should fight fire with fire! You should fight everything with fire."
doriii
PostSubject: Re: Help with making my 1850 into a 1250   Fri Jan 08 2016, 06:44
thanks for the reply Very Happy
yeah at 1250 there will prolly be less AV so it makes sense to drop the sybarites.
so its like this
succubus
glaive, HG
100pts
160pts
4x5 warriors 1 blaster
dual cannon venoms
480pts
dual DL razorwing
140pts
5 scourge 4HWB
120pts
2xtriple DL ravagers
250pts
i think im comfortable with this list, i had been working out the grots but more often than not the come in handy vs alot of stuff that our shooting cant handle with easily
two razorwings are also a bit too much in 1250, almost 300pts that might not do anything until turn 4
hydranixx
PostSubject: Re: Help with making my 1850 into a 1250   Fri Jan 08 2016, 13:13
If you do find them under performing, you can always drop one razorwing in favour of another ravager or squad of warriors. You'd have a little extra to spend, so could invest in Armour of Misery on the succubus, or some night shields for your ravagers.
