 Move Through Cover USR and its effect on models in same unit
PostSubject: Move Through Cover USR and its effect on models in same unit   Tue Dec 09 2014, 06:42
Move Through Cover gives the unit an extra dice when moving and no penalty when charging through difficult terrain. Then the rules goes on to state that the model auto pass dangerous terrain tests. So does this mean the unit also passes dangerous or just the models with this rule. Played Dark Artisan and they arrived via deepstrike (Webway on the Haemie) in terrain. Should the Haemie have tested?
"I'm alive from this pain!"
Vasara
Incognito assault marine
Vasara
PostSubject: Re: Move Through Cover USR and its effect on models in same unit   Tue Dec 09 2014, 07:15
In the 6th MTC was "at least one model with this special rule" but I can't remember 7th ed.
New Dark Eldar in Tournaments: Wins: 17 Draws: 2 Losses: 8
ETC 2013 DE/Eldar player (4th)
ETC 2014 Coach (16th)
ETC 2015 Captain, Eldar/DE (10th)
Painting blog
PostSubject: Re: Move Through Cover USR and its effect on models in same unit   Tue Dec 09 2014, 08:08
Still the same.
Dra'al Nacht
PostSubject: Re: Move Through Cover USR and its effect on models in same unit   Tue Dec 09 2014, 11:16
Actually, the auto passing of Dangerous Terrain tests clearly specifies 'a model with. . ' so in the OP's example- yes, the Haemie would have to test.
fala
fala
PostSubject: Re: Move Through Cover USR and its effect on models in same unit   Tue Dec 09 2014, 14:33
I was to write the opposite, but you are right. Only the additional distance rolls are shared within the unit, avoiding of the dangerous test is not.
http://fala13.wordpress.com
1++
PostSubject: Re: Move Through Cover USR and its effect on models in same unit   Wed Dec 10 2014, 06:07
Thanks for clarifying guys!!
